Is there a way to transfer Creo licence from old to new server?
The answer is NO, as the new server will have a different NiC with a different MAC address you will need a new license.
OR you could take the old card out if it is a 'daughter board' assuming the name and IP of the new server is the same as the old.
You will need to request a new license from PTC.
