What is InfoTable ?
An InfoTable is zero indexed, ordered array of javaScript objects which expose sameproperties. Since an InfoTable is an Array of Objects, it can also be thought of as a table where the array entries are rows and the object properties of each object in the array are the columns.
For example :
var people = [
"name": "dinesh",
"age" : 21 ,
"mobileno" : 025514855
"name": "senthilkumar",
"age" : 55 ,
"mobileno" : 622488596
As you can see InfoTables only contains the same type of object.This is achieved using another ThingWorx specific mechanism called Data Shape
Service For Json Format to DataShape:
var people = [
"name": "dinesh",
"age" : 21 ,
"age" : 55 ,
var params = { dataShapeName: "SampleDataShape" /* DATASHAPENAME */,
infoTableName: "alertService1" /* STRING */ };
var result = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);
var len=people.length; // finding the length of the JSON
for( var i=0;i<len;i++){
// TRAVERSE the json
var row = new Object(); // create the row for every records.
row.Name=people.name;
row.age=people.age;
row.mobileNo=people.mobileno;
result.AddRow(row); // it will add the records in the datashape.
Result of the service:
Then select the datashape for Mashup Loading:
1) edit the Service(you created).
2) click input/output bar.
3) add datashape(you created)
4) check the output should be Infotable.
this is helpful for me. thank you dinesh
i am new to thingworx this was very helpfull. thanks
