PTC Creo 3.0 Academic allways install to c:\
jmuhl
I have a problem to change the location of the installation, usually the setup will install to c:\...\PTC.
I want to install Creo to a seperate partition, if I change the location while installation process, the setup ignore and install to c:\...PTC
I had an clue, that the licence file may the reason why, because this location can not be changed, so i tried to install Creo without the licence.
No sucess.
So, anyone with similliar problems, or an idea to solve this problem ?
Glad for your help
MartinHanak
24-Ruby II
(To:jmuhl)
to finish entering custom installation path properly, you have to press ENTER key on the keyboard.
MH
Martin Hanák
MartinHanak
24-Ruby II
(To:jmuhl)
MH
Martin Hanák
This was kind a tricky, thanks a lot!
