Re-Licensing Creo 3.0
RoyHandley
3-Visitor
Hello
I am trying to renew my license for Creo 3.0 Schools Edition and have followed the guidance given in the document “Creo 3.0 – Schools Standard Edition – Re-Licensing Guide”, mentioned elsewhere on the Academic Support Forum.
On each of the several  occasions I have tried, rather than getting the “Success!” message, I simply get “Failed”.
I have followed all guidelines including turning off firewall etc. and running Reconfigure as Administrator (Windows 7).
Could anyone please advise?
Thank you
Roy Handley
maybe you can test Product Code for university students ... BK400407EDSTUDENTUNICL
MH
Martin Hanák
14 REPLIES 14
did you receive license file via email ?
MH
Martin Hanák
Hi Martin,
No I didn't receive a license by e-mail. I checked this several times having read previous posts on the forum suggesting that this may happen.
Roy
if I were you I would try new installation of Creo into new (this means different) installation directory. You do not have to uninstall current installation.
MH
Martin Hanák
Thank you for the suggestion. I will try this for now.
Roy
Hi Martin
Tried a reinstall but can't get past the licensing screen without getting a failure.
Ron,
I have already seen Failure in several discussion. SImply ignore it. The only important thing is ... did you receive licensing email, now ? I hope that you were asked to login to PTC during installation.
MH
Martin Hanák
Martin
Yes I did log in when requested.
No e-mail has arrived!
Roy
My blind shot ...
in Windows Explorer go to C:\ProgramData\PTC\Licensing directory. It probably contains old license files. Move them somewhere else. When directory is empty, try new installation again.
MH
Martin Hanák
Martin
I do not have a directory by that name but I assume you are referring to the location where the original license (received by e-mail) was placed?
I have been to that location and moved the expired license file but I still get failure when trying to re-license.
Roy
MH
Martin Hanák
Martin
Thank you for this. This solution has worked and my Creo 3.0 is now working again!
Must confess that I don't really understand why this should be necessary but Thanks again anyway.
Roy
Hi Martin
Further to yesterdays discussion, I have today received via e-mail a license from "-" . However, the text of the e-mail refers throughout  to "PTC Creo 2.0 Student Edition".
Would this license file work with Creo 3.0?
I can't understand why the 'wrong' license has been sent when, presumably,  it was an attempt to re-license Creo 3.0 on my computer that prompted the e-mail!
Your comments would be much appreciated.
Roy
Roy,
I guess that email text is not up to date. Simply ignore it and open license file in Notepad.
Locate line similar to following one ...
INCREMENT CREOPMA_SchoolSTD3 ptc_d 34.0 ... and so on
CREOPMA_SchoolSTD3 ... license name
34.0 ... license version ... 34.0 = Creo 3.0
MH
Martin Hanák
Martin
Thank you for clarifying this. I have checked with Notepad and the license is indeed for Creo 3.0 so I have now successfully relicensed my copy using this e-mailed license rather than continuing to use the university code as previously suggested.
It is a pity that the e-mail text has not been updated as I am sure this will cause other users to pose the same questions as myself.
Thanks again for your assistance.
Roy
