TWX_Academic_RaspberryPi.zip file not found
btiruveedula
Hello Friends,
I am working with the academic program exercise 'Connecting to Raspberry Pi'.
The pdf document is referring to the project files named "TWX_Academic_RaspberryPi.zip" but there is no link available over there.
Can you help me to know how to get that file in order to continue with the exercise.
Thank you.
Bhanu
Hello, Bhanu.
I'll try to locate someone who can help you out with this.
Thanks!
-- Craig A.
Hi Bhanu Tiruveedula​ ,
In order to download the TWX_Academic_RaspberryPi.zip you can use the following documentation https://www.ptc.com/-/media/Files/PDFs/Academic/RPi_071017.ashx?la=en&hash=DE94054D1F49BD467B8D8F527B518AAB042F7650   see the reference for downloading at   http://apps.ptc.com/schools/references/TWX_Academic_RaspberryPi.zip
Ciprian
