Within Codebeamer suggestion ideas are it is not possible to search, therefore a field in the top for searching would be great. Otherwise I have to manual went through a lot of ideas.
Hi @CBI
I want to make sure I understand correctly. Are you trying to search this Idea board? If so, you can use the search icon in the header. If you are on the idea board it will by default scope your search to that board.
Hi @CBI
Ok, thank you.
