I have recently installed creo ptc 7.0 student edition on my pc and now i have the problem, that my planes dissapear whenever i rotate the part/coordinate system. And also the Backgroung is completely white wgile it should be grey-ish to my knowledge. How do i fix this?
usually these problems are caused by wrong version of graphic card drivers installed.
Please publish:
PS: also the programm doesn't snap to the active plane when making a sctetch/extrude/revolve like its supposed to and i have to center an allign it manually.
Please publish:
