The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
Hello.
I use creo 8 student version and my license expires tomorrow.
I tried to do It but when I fill the user name and password the message is: cliente nao verificado.(customer not verified)
How can I update It?
Thank you.
Hi @Jbrittes, you should have received a PTC account verification email to the inbox you used to register your PTC account. Clicking the verification link (or going to https://support.ptc.com/appserver/common/account/ssl/verify_basic.jsp and entering your email address + code from your verification email) should get you past this error.
Best regards,
Peter.
Good evening, Peter.
I received an email from support with a new .DAT file and this resolved the issue. Should I still perform this procedure you suggested?
Thank you for your attention.
Brittes
Translated by the Community Moderation using Google Translate
Hi, Brittes, thanks for confirming and I'm happy to hear you've resolved the license issue. In answer to your last question, yes, it's always a good idea to validate your account. This step increases security and is needed to access to other Digital services from PTC.
Best regards, Peter.
Olá, Brittes, obrigado por confirmar e fico feliz em saber que você resolveu o problema de licença. Respondendo à sua última pergunta, sim, é sempre uma boa ideia validar a sua conta. Esta etapa aumenta a segurança e é necessária para o acesso a outros serviços Digitais da PTC. Atenciosamente, Peter.
