FAQ's Related to Creo Trial
Harry_Seth
Creo Parametric Trial - FAQ's
How many times does one user can opt for Creo Trial? /Limitation for Creo Trial usage per user/system Host ID
  • Host Id and the email ID gets registered on the PTC database hence, User can access Creo Trial only once per system.
Is it possible to open Creo Trial data/files in Creo Parametric commercial version?
  • No, commercial version files like Assemblies and Parts will not be compatible with the tryout version, and vice versa. It was designed only for demonstration and practice purpose
Does Creo trial always takes the latest version to install?
  • Yes, Creo Trail is always installed with the latest release of Creo Parametric
Is it possible to install previous version of Creo Trial?
  • It is not possible to install any previous version as Trial on the system.
How to extend the trial period more than 30 days
  • The trial period is valid only for 30 days. If it needs to be extended, please contact our Sales team.
How many sessions of Creo can be launched?
  • Only one session at a time can be launched.
Is quality agent must be compulsory registered in order to continue using Creo Parametric in Tryout mode?
  • In general, Free or Trial products require Quality Agent. It is not possible to bypass Quality Agent option while installing Free Trial of Creo Parametric
What are the supported Operating Systems? What are the hardware requirements for Creo Parametric Trial?
  • To get more details kindly click here
 Who do I contact if I have an  issue related to Installation ?
  • You may post your query in PTC Community . PTC Agent/Moderator  will answer your question. There is a high chance that a community peer may reply to your query / question and help address the issue user reported.
Is Technical Support available for Creo Parametric Trial software
0 REPLIES 0
