I'm having an issue with my imported DWG file disappearing. Whenever I import it at 1:1 scale, the sketch disappears. It will only stay if I keep the scale at a higher number, The sketch is a simple cylinder profile which i'm goign to revolve. Is it having problems with adding dimensions and thats why it's disappearing? The steps I take are begin a new sketch on a plane and choose Get Data>File System. Choose profile DWG and change import scale to 1:1. When I hit the green check mark, the sketch disappears. Help??
Hi Victor,
As this is more of a user question rather than a training-related question, I would suggest re-posting your question to the Creo community. There, your chances for receiving advice from your peers are higher.
Bettina
Thanks for the info.
