How to create multiple references in the mechanism's 3D connections?
avijayakumar
In my mechanism below I want to simulate the bouncing shown in example provided in the exercise eleven of the How to Model Anything. The yellow man consistently goes straight through the green box. I think that it is due to the fact that I do not have all the surfaces referenced as is done in the 4th picture. How do i do multiple 3D connection references, as I only have one surface 3D connection reference
Hi Abhishek,
To accomplish this, you can use multiple 3D connections between the man and the box. You'll need to make a connection for each wall of the box.
Let me know how it goes.
Chris
Hi Mr.Carr,
Thank you so much for your help! I understand that I should create a 3D connection for each wall of the box, but Creo is only letting me create one 3D connection. When I try to click on another wall to create another It just edits the original 3D connection.
Could you describe the steps involved in how to add multiple 3d connections?
Abhishek
Hi Mr.Carr,
I think my question was missed in the thread, could you possibly answer?
Abhishek
