JsonToInfotable(service).
ds-21
7-Bedrock
What is InfoTable ?
An InfoTable is zero indexed, ordered array of javaScript objects which expose  sameproperties. Since an InfoTable is an Array of Objects, it can also be thought of as a table where the array entries are rows and the object properties of each object in the array are the columns.
For example :
var people = [
          "name": "dinesh",
            "age" : 21  ,
          "mobileno" : 025514855
          "name": "senthilkumar",
            "age" : 55  ,
          "mobileno" : 622488596
As you can see InfoTables only contains the same type of object.This is achieved using another ThingWorx specific mechanism called Data Shape
Service For Json Format to  DataShape:
var people = [
           "name": "dinesh",
            "age" : 21   ,
            "age" : 55   ,
var params = { dataShapeName: "SampleDataShape" /* DATASHAPENAME */,
              infoTableName: "alertService1" /* STRING */ };
var result = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);
var len=people.length;         // finding the length of the JSON
for( var i=0;i<len;i++){
                    // TRAVERSE  the json
    var row = new Object();         // create the row  for every records.
    row.Name=people.name;
    row.age=people.age;
    row.mobileNo=people.mobileno;
    result.AddRow(row);           // it will add the records in the datashape.
Result of the service:
​Then  select the datashape  for Mashup Loading:
1) edit the Service(you created).
2) click input/output bar.
3) add datashape(you created)
4) check the output should be Infotable.
kraj1
(To:ds-21)
this is helpful for me. thank you dinesh
dsenthil
2-Explorer
(To:ds-21)
i am new to thingworx this was very helpfull. thanks
