Is there documentation on what settings and changes are made for the Custom Schools Edition setup from the out of the box Creo 3? Can you share it or post a link to it?
Thank you,
Dan Glenn
Mentor, FTC Green.Griffins; 10092
San Diego, CA
Dan, try this discussion for more info.
Restore Sketcher Ribbon UI in the Creo Schools Configuration
