Teacher Showcase: Katy Barnes, Accrington Academy
ptc-4630332
Designing a MP3 speaker case influenced by the theme of high speed trains. I used a varety of modelling techniques within the software to create a series of parts and assemble them together before rendering them as a CAD model. Below are the stages I took in carrying out this modeling process. I was trained by Sheffield Hallam University.
Image one shows the protrusion for the basic shape of the body. This is part one
Image two shows the body shape after applying a series of sketches, extrusions and rounding of edges.
Image 3 shows the body of the speaker part after it has been shelled. This will create space for the components.
Image 4 shows the body shape part in half where an area been created for the PCB board and battery. These were created using a series of sketches and extrusions.
The image below shows the engineering drawing for one side of the speaker casing.
Image 6 is a rendered side to the speaker casing. It is an assembly of all the components mated into the compartments that were created.
Image 7 is the final rendered model for the speaker casing where the 2 side parts have been mated together in another assembly.
Katy, I like the design you came up with and the way you modelled it. The shape and scale packages the components very well.
You refer to image 6 being a render.  I cannot be sure but think this is a normal model view. Used sensitively, the render tools can make the product look almost real.
Take a look at the new Freestyle tools in Creo, they are great for the orgnanic shapes product designers use.
Lovely work, well done!
