Hello Community,
I recently installed the latest version of Thingworxs. While trying to import the Twilio Extension, I'm getting errors.
I re-dowloaded the extension from the Market Place and still not able to get it working, the error is around "Export file Missing Version". Below the log fiie
2016-06-12 17:07:25.494-0600 [L: INFO] [O: c.t.w.Importer] [I: ] [U: kmorales] [S: ] [T: http-nio-80-exec-1] Starting entity import of C:\ThingworxStorage\extensions\temp\Twilio_Extensions_07ce51d3-79ca-41ca-b644-8daff607cbc7\Twilio_Extensions\metadata.xml
2016-06-12 17:07:25.572-0600 [L: INFO] [O: c.t.migration] [I: ] [U: kmorales] [S: ] [T: http-nio-80-exec-1] Export file missing version information. No migration will be performed.
2016-06-12 17:07:25.572-0600 [L: INFO] [O: c.t.w.Importer] [I: ] [U: kmorales] [S: ] [T: http-nio-80-exec-1] Successfully added for import C:\ThingworxStorage\extensions\temp\Twilio_Extensions_07ce51d3-79ca-41ca-b644-8daff607cbc7\Twilio_Extensions\metadata.xml
2016-06-12 17:07:26.054-0600 [L: ERROR] [O: c.t.e.u.ExtensionPackageUtilities] [I: ] [U: SuperUser] [S: ] [T: http-nio-80-exec-1] ERROR - un-installing Extension Package: Twilio_Extensions
2016-06-12 17:07:26.054-0600 [L: WARN] [O: c.t.s.m.ExtensionPackageManager] [I: ] [U: SuperUser] [S: ] [T: http-nio-80-exec-1] Unable to delete Extension: [Twilio_Extensions] ERROR - un-installing Extension Package: Twilio_Extensions
2016-06-12 17:07:26.054-0600 [L: ERROR] [O: c.t.e.u.ExtensionPackageUtilities] [I: ] [U: SuperUser] [S: ] [T: http-nio-80-exec-1] Unable to delete Twilio_Extensions:2.0.0. This is likely due to other errors: ERROR - un-installing Extension Package: Twilio_Extensions
Keiner, can you try restarting your Tomcat and then re-importing? If you go to ThingworxStorage/extensions folder, do you see this extension there?
i have the same problem ,i restarted the tomcat and the Tingworx/extension folder i saw the extesnion i imported ,but not in the mashup
Hi, did you find any solution for this issue?
