Hi!
I'm spending hours to try to change the language of my PTC Creo, but without success. I already chose to add the language german in the Installation window, and what I read everywhere is to add a specific line in a PSF file, however there is no PSF file on my computer ; the Folder bin, which took a lot of efforts to find, has no file (just another Foldder wtih XML files).
Can I add a psf file? How? Can somebody help me please to change the language from French to German
parametric.psf file is located in
directory
Also you have to enable displaying of filename extensions.
directory
Hi @Wlivier,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
