Hello, i am using creo 3.0 and I had to use the HTTPS link to download it. After unzipping the file with winrar and starting the setup, I did not have the option to enter the license code and install the application. I am using a student account if that is important. What is the issue and how can I resolve this?
If you are using setup-schools.exe, you will not need to insert any product code. the installation will finish without asking for a code.
In case you are using setup.exe, you will get to the licensing window, where you need to insert the product code.
If you have any issues, please provide more information and screenshots with the error message.
Alex
@ok27 wrote:
[cid:25a5a631-f48d-497b-a662-cd5009ba484b]
[cid:62fcf984-6643-4312-adf8-3734027e8afe]
[cid:4c8a8968-9f9f-451e-a16c-be8ef7bbea3e]
[cid:024fb88d-bc05-4f7e-8606-20b19a2be8f8]
[cid:277a6760-c4cf-41d3-8705-451a6ddc2c76]
[cid:4c2f988d-226d-4fe7-9a9a-b0a42601ddb5]
[cid:0ba62940-615a-4c0c-8858-7c363e4d391b]
here is every step that I take one by one. I do not have the license code area and after i press "finish" i do not get anything new. I await your assistance if possible, thank you.
please save screenshots into .png files and upload them using camera button
