Using same part with different dimensions
YashYadav
I am looking for the solution to my problem: How can we use a single part in an assembly with various dimensions,
I wanted this to change the length of the Bosch Aluminum Profiles without making different part file of variable length in an assembly model.
Regards
Yash Yadav
for simple solution, try Family Table. You can add series of dimension with excel table on it.
