I have a message Error 0x0000000b and i can not start Creo Parametric. I need your help !!!
Hi Karim,
This is a know issue some people are having with Creo 2.0. It occurs in the later build codes and we're working on a solution to the problem. In the meantime, your best bet is to download Creo 2.0 M130 from the link below and install it. That's the latest version that has been verified to be error-free.
http://www.ptc.com/appserver/auth/it/esd/academicFree.jsp
Let me know if that helps.
Chris
