installation creo 7.08 student edition; license request failed for feature
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
Hello All,
After Installing creo7.08 student editon according installation guide I recieved error "license request failed for feature"
In parallel I recieved an sw license email prt email. But what to do with this package? How to install this?
I hope, somebody could help.
Kind regards
Figolino
- Labels:
Creo Student Edition
Installation
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
@ED_10492786 wrote:
Hello Martin, thank you for your support! See enclosed as requested licence email. I covered my email and contact data with xxx. I am looking forward to your hints to solve the problem.
to resolve your problem, you have to edit parametric.psf file located in Parametric\bin subdirectory. In my Creo 7.0.9.0 installation the path to the file is E:\PTC\Creo7_090\Creo 7.0.9.0\Parametric\bin\parametric.psf.
Save sw_license_email_84994mod.txt for example into C:\Temp directory (you can save it into any other directory).
Open parametric.psf file in Notepad, locate following lines, check/modify their contents and save the file.
ENV=PTC_D_LICENSE_FILE-=C:\Temp\sw_license_email_84994mod.txt
ENV=CREO_APP=PMA
ENV=CREOPMA_FEATURE_NAME=CREOPMA_SchoolSTD6 ()
Important note:
Your license file is generated for network card with MAC address 6C-C2-17-78-4D-45. This network card must be alive when you start Creo. You can open Command prompt window and run ipconfig /all command to check, whether the network card is available.
Martin Hanák
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
There was a similar question before:
- "License request failed for feature Creo 7.0": https://community.ptc.com/t5/PTC-Education-Forum/License-request-failed-for-feature-Creo-7-0/td-p/813667
- "Creo 7.0.0.0 student version error "License request failed for feature"": https://community.ptc.com/t5/PTC-Education-Forum/Creo-7-0-0-0-student-version-error-quot-License-request-failed/m-p/700585
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
@ED_10492786 wrote:
Hello All,
Kind regards
Figolino
please upload license. I will check its contents and give you an advice what to do.
Martin Hanák
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
ENV=CREO_APP=PMA
Important note:
Martin Hanák
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hello Martin,
thank you very much!
Your guide worked well to solve my installation problem.
