All distances of the points to be Integer
ttokoro
20-Turquoise
(This is only a puzzle to fun! )
Tokoro.
  1. Make a circle with its center (0,0) and radius r.
  2. Make five points on the circle with all distances of the points to be integer.
  3. The puzzle is to find the minimum of r.
  4. Next, the same puzzle except the number of points are 10.
  5. The answer of 4 points attached.
I found the lengths 4,6,4,6,4 by trial and error until I got integer results for the diagonals.
Regards
Terry
34 REPLIES 34
I'll play  (The definition does not need the radius be an integer?)
You are not free on the radius. Because the diagonals are twice the radius. Hence radius must be an integer times 1/2.
(To:LucMeekes)
Which diagonal of which pentagram must be a diameter of the circle? There may be a solution where one diagonal or maybe even one side of the pentagon is a diameter but sure not necessarily.
Even with four points its not demanded to be a regular quadrilateral or to have any symmetries. Its just the solution shown which happens to be at least a rectangle. And I see no proof that 5/2 is the minimum for the radius in case of a quadrilateral.
I have no clue how to proof that the solution for 4 points shown really is the minimum (wrt the radius) and that not maybe an irregular quadrilateral would not lead to a smaller radius.
Nor have I any idea how to use Mathcad to help finding any solution with 5 points, let alone the minimum one.
Its clear that it suffices to demand for all distances to be rational as we then can blow up the figure as necessary to make them integer, but I don't think that knowing this is much of help.
LucMeekes
(To:Werner_E)
I stand corrected.Smiley Embarassed
Correct, but I guess you overlooked that ALL distances of any two points must be integer. This includes the diagonals which in case of your pentagon are not integer.
Thanks Werner
thought it was too easy
Cheers
The answer of 3 points.The answer of 3 points.
Thanks for your time to fun! Your answer is correct for 3 points.
By the way, connect all n points on the circle is good programing exercise for the students.
 Connect all 30 points on the circleConnect all 30 points on the circle
Have an answer for 5 pointed problem.
Sides are 4,6,4,6,4 in a 4.131182 radius circle.
Diagonals are 8,8,8,7,8 all integers.
Calculation sheet enclosed.
It is based on solution of intersection of two circles one centred at origin and radius R, the other centred at R,0 with radius equal to side length.
Starting with next side, place a circle of radius the length of the side and centre at last location obtain the intersection point.
Repeat this for each side.
This is repeated around the circle to get a closing angle that should equal 2 pi.
Manually ratio  the closing angle to 2 pi to get the next starting radius.  Just do this till maximum accuracy is obtained
Cheers Terry
To be exact, that radius is 16/sqrt(15).
Great Solution!
But how do you get the side lengths 4,6,4,6,4 ?
Once you have decided that the sides should be of that lengths, the radius can easily be found using symbolic solve:
(To:Werner_E)
Regards
Terry
ttokoro
20-Turquoise
(To:ttokoro)
ttokoro
20-Turquoise
(To:ttokoro)
ttokoro
20-Turquoise
(To:ttokoro)
ttokoro
20-Turquoise
(To:ttokoro)
This answer of n=8 is r=
‎It is very large and the shape is not smart. So, the best answer should be more small.‎
ttokoro
20-Turquoise
(To:ttokoro)
Mathcad Prime 6.0 sheet. n=8
n=9
ttokoro
20-Turquoise
(To:ttokoro)
ttokoro
20-Turquoise
(To:ttokoro)
ttokoro
20-Turquoise
(To:ttokoro)
ttokoro
20-Turquoise
(To:ttokoro)
ttokoro
20-Turquoise
(To:ttokoro)
ttokoro
20-Turquoise
(To:ttokoro)
I find a new point of No.14. So the r reduced to
ttokoro
20-Turquoise
(To:ttokoro)
This calculation also limited by 15 digits, It is about 100 points on the circle. May be from 2 to 5 points are the best solutions.
ttokoro
20-Turquoise
(To:ttokoro)
Find the new 4 points answer.
ttokoro
20-Turquoise
(To:ttokoro)
Answers of n=4 to 13. No.5 is find by terryhendicott.
ttokoro
20-Turquoise
(To:ttokoro)
New stab series (red line) reduces to only 7% at 50 points.
(3663075,0) (-3663075,0)
(3649821,311328) (-3649821,311328) (-3649821,-311328) (3649821,-311328)
(341859,3647088) (-341859,3647088) (-341859,-3647088) (341859,-3647088)
(3596925,693000) (-3596925,693000) (-3596925,-693000) (3596925,-693000)
(723075,3591000) (-723075,3591000) (-723075,-3591000) (723075,-3591000)
(1025661,3516552) (-1025661,3516552) (-1025661,-3516552) (1025661,-3516552)
(3491709,1107288) (-3491709,1107288) (-3491709,-1107288) (3491709,-1107288)
(1672419,3259008) (-1672419,3259008) (-1672419,-3259008) (1672419,-3259008)
(3244899,1699632) (-3244899,1699632) (-3244899,-1699632) (3244899,-1699632)
(3219171,1747872) (-3219171,1747872) (-3219171,-1747872) (3219171,-1747872)
(1774749,3204432) (-1774749,3204432) (-1774749,-3204432) (1774749,-3204432)
(2040675,3042000) (-2040675,3042000) (-2040675,-3042000) (2040675,-3042000)
(2348931,2810808) (-2348931,2810808) (-2348931,-2810808) (2348931,-2810808)
By H. Fujiwara.
ttokoro
20-Turquoise
(To:ttokoro)
ttokoro
20-Turquoise
(To:ttokoro)
Today, Suzuki find the new smallest answer for n=5 to 18.
n=5 The answer is.
[r 0],7,5,3,5,3.
n=6. Same r and add image.png and [r 0],5,3,5,3,5,3.
