Hello. I'm currently doing some basic unbalanced 3 phase load calculation with complex numbers. I decided to use a matrix for this purpose. Any suggestions for a faster and better way to find the phasor angles WITHOUT the added +30 deg. vector angles between phase and line voltage.
Thanks!
