Array elements must be scalars
ptc-4499387
Hello all,
Could you please tell me how to over come this scalars problem? Thank you.
Lawrence
The square brackets around the second term in your equation are forcing prime to assume that this is a 1 element array & this is causing the confusion.
Once this is corrected there are 2 ways to produce an answer from the information given (as attached)
Hopefully one of them will be the result you want
Andy
Andy
