Bug with symbolic solve?
Has anybody an explanation why the symbolic solve produces that many wrong solution if used without the modifer "fully"?
May we call it a bug? Are there other examples?
I think it's clear enough where the extra solutions come from; Mathcad must do something like the following on solving the equation.
Alan
7 REPLIES 7
RichardJ
(To:Werner_E)
. Is there something else we might call it?
Because there's a bug
(To:RichardJ)
Hmm, its PTC - maybe its a feature!? PTC marketing sure can make that possible.
Yes, and obviously "fully" makes the symbolics to think about its results a second time
Alan's explanation make it clear whats happening - false solutions coming from taking the equation to the power of 4.
and too few solutions:
I use others tools in some cases:
Thats indeed interesting and I wouldn't have expected a different behaviour here (because its an even root exponent).
More bugs than I wanted to experience ;-(
Alan
(To:AlanStevens)
Thank! Yes, at least with your explanation its clear what happens.
Nevertheless a bug which should not happen.
Also intersting the different behaviour when using the fourth root instead.
I know the difference between (-1)^(1/3) and the third root of -1 (only the latter is -1) but not sure about the fourth root and how the symbolics sees it.
Werner
