Calculate and Communicate with PTC Mathcad Prime 3.0
bedmonds
7-Bedrock
Full list of worksheets
Want a free copy of PTC Mathcad Express? Download your copy today.
Authors: Hans Wesselingh, Hans de Waard
This course will help you to learn PTC Mathcad in 25 live lessons of an hour each. These cover worksheets, functions, plotting, programming, units, statistics, calculus, vectors and matrices, linear and non-linear equations and differential equations. Some hundred exercises include examples from applied math, physics, chemistry and physiology.
To begin, download the lessons and exercises from the PTC website. Open the first lesson in Prime 3.0 and work through it. The course consists of read-only Mathcad files, which can be viewed and modified in the free Mathcad Express. The course is also available as a book from Delft Academic Press. This can be ordered via Amazon.
What is New: The largest change in Prime 3.0 compared to Prime 2.0 is in the editing of equations. These are handled in lesson 6. You will find the new method of editing to be more natural than the old one: it closely follows that of other Windows programs. There are smaller changes in lesson 1 (the interface), lesson 3 (templates), lessons 7,8 an 9 (plotting) and lessons 10 (labels and global variables). We have partly rewritten lessons 11 and 12 on programming and lessons 13 through 16 on statistics.
Worksheets marked with use PTC Mathcad premium features, otherwise they are Express compatible. All worksheets created in PTC Mathcad Prime 3.0.
Chapter
ExerciseDescription
Introducing Mathcad
Mind Map
PTC Mathcad is very useful for problems where you need to be flexible and creative: when you are learning a subject, doing homework, designing, or developing a new product or theory. You can even write a book in it, as this text shows.
Handling of Text
Typing Exercise
PTC Mathcad has one great advantage over other programming languages: it is self-documenting. You will still be able to understand this Mathcad file if you load it in a years time. The program is not a full-fledged text editor, but as you can see in this chapter, text handling is good enough for many purposes.
Worksheet LayoutMy TemplateWhen doing a quick calculation, you may not worry about the layout of your worksheet. However, for a report or a book, the layout needs to be chosen such that it does not distract the reader. For that, PTC Mathcad has integrated lots of features.
Mathcad as Calculator Quick ArithmeticPTC Mathcad is a good calculator, certainly if you have a numerical keypad. It gives a record of calculations which can be easily stored or printed.
Variables and FunctionsDestructive DefinitionsWhen you have mastered the use of variables and functions you will begin to realize the capabilities of Mathcad. This chapter explains how to define and use variables and functions.
Editing of EquationsEdit EquationsTo become a proficient user of PTC Mathcad you must learn to edit equations. For that, check out this chapter!
Ranges and Plots
Great Graphics
Logistics Map and Chaos
Pasting Plots
This chapter explains how a set of counting subscripts is formed using a range variable and how the range variable is applied in plotting of a function.
2D Plots of Functions
Linked Lines
Quadratic Quest
Log Plots
Fun Plots
In this chapter we can explore the many variations in plots. To do that we use the same terms as in lesson 7. Make sure you have the names of the plot elements in your mind.
3D Plots of Functions
Spatial Symmetry
Leaf of Descartes
Donut
Plot of a Spring
3D plots in PTC Mathcad are similar to 2D plots. However, there are differences of which you should be aware of. PTC Mathcad has two kinds of 3D plots: the true 3D plot with three axes as well as the contour plot. Two find out more about them check out this chapter.
Labels and Units
My Template with Labels
Food in the Body
Dissolution of a Tablet
Plate Viscometer
Temperature in a Spray Dryer
Volume of an Ideal Gas
Falling Particle
Flow from a Vessel
Concentration in a Mixture
Vapour Pressure of Water
In practical calculations you often need to use the same letter to describe different entities. For example the letter 'g' might be used to describe a variable, the unit gram, the gravitational acceleration and some function g(x). You can do this in PTC Mathcad without any confusion by giving these entities a different label.
Programming Branches
Cylinder Modified
Truncated Sine
Black or White
Specifications of a Tablet
Singular Singularities
PTC Mathcad contains a programming environment that greatly extends its capabilities. Despite the small number of commands you can construct the three main elements of any programming language: actions, branches and loops. That combined with the many other parts of Mathcad that you have learned in the previous chapters gives you humongous possibilities.
Programming Loops
Filling a Vector
Filling a Matrix
Counting Exam Scores
Timing
Sum of a Series
While versus For
In this second lesson on programming the focus is on 'loops'. These repeat calculations in different ways - often many times.
Statistics
Start Simply
Books per Student
stdev Uniform Distribution
Central Limit Theorem
stdev of Means
In this lesson (and the following ones) we look at data which will be regarded as two vectors of equal length. We will show how to summarize the behaviour of data by the mean and the standard deviation. Further we discuss two of the random number generators in PTC Mathcad.
Distributions
Tossing a Coin
Dice and Cards
False Positives
Standard Normal Distribution
Binomial and Normal
Packs of Sugar
In this chapter we look at a few probability distributions. The two main ones are discrete distributions and continuous distributions. To find out more about those, read this chapter!
Testing
Simple Samples
New Machine for Tablets
Jam and Bottle
New Machine Again
The t-Distribution
Small Samples
This chapter considers sampling and testing of data.
Data Analysis
Response to Glucose
Fitting a Quadratic
Drug in the Body
Different Lines
In this chapter we look at how to handle data, specifically how to find relations between variables from experiments. We will look at two techniques for handling experimental data: Data fitting (regression analysis) and interpolation between data points.
Input Output
Sunspots
Excel Ellipse
You can use variables and functions from other Mathcad files in your worksheet. Further PTC Mathcad also allows you to read data from Excel and use Excel tables in your worksheets.
Symbolic Calculus
Some Derivatives
Indefinite Integrals
Slope Area and Average
Limits
Function with a Hole
The Cannon Ball
Fractal Lung
PTC Mathcad is a layout program in which you can place text and math regions. In the previous chapters, the math regions have been numerical. However, you can also use these to do 'symbolic' calculations. These will allow you to redo classic 'calculus' on the computer: differentiation, integration, limits, series... and all these operation with equations as you would write them.
Solve and Series
Linear Equations
Cubic Equations
More Problems
Some Series
Same Series
In this chapter we explore variations of symbolic evaluation using keywords and modifiers. We apply these to get a symbolic solution of equations, and to approximate a function as a series of polynomials.
Shapping Equations
Expand and Factor
Evaluate and Simplify
Partial Fractions
Float and Assume
Exponential Equations
Equations are often not in the form that you would like them to be. PTC Mathcad has several tools to help you shape equations by rearranging or substituting them.
Vectors and Matrices
Manipulating Matrices
Symmetric and Skew-symmetric
Dot Multiplication
Simple Inverses
Linear Equations
Inverse of a 3x3 Matrix
You may know a lot about this subject without having realized. Calculations in Excel are vector and matrix operations. You can do these in PTC Mathcad with the advantage that calculations are much easier to follow and you are less likely to make any mistakes.
Linear Equations
Linear Equations A
Linear Equations B
Blood Circulation Short
Plane Transformations
In these chapter we look at applications of vector and matrix algebra. These applications often require the solution of sets of linear equations.
Nonlinear Equations
Non-linear Equation
Three Linear Equations
Dissociation of a Weak Acid
PTC Mathcad can solve implicit sets of linear and non-linear equations. It does this with a clever multi-variable interation technique. If you provide an approximate solution, then the program will improve your estimate. Because of that you must understand the behavior of the functions that you are studying.
Solving with Functions
Guess Values
Two Nonlinear Equations
Solving of equations is important for practical problems. For that PTC Mathcad has the function 'solve block' which you learn how to use in this chapter. .
Differential Equations
Absorption in the Intestines
Cat and Mouse Equations
Body and Drug
Ordinary differential equations contain two kinds of variable: dependent and independent. In this chapter you learn how to solve these in a solve block.
EndingEndingWe like to end with two bits of advice. Firstly that real problems take longer and secondly there is a lot more in PTC Mathcad that you have seen in these chapters. For more details, check out this chapter.
0 REPLIES 0
