Jun 5, 2021 12:40 PM UTC
Combo-box alternative methods of utilisation
Hi All,
These may be some stupid questions, but new to this environment from an excel background...
I have a number of questions which pertain primarily to how to use data within list / combo-box etc. to be able to extract a number of standard parameters associated with, snippet's below & file attached
ttokoro
ttokoroAnswer
Jun 9, 2021 11:26 PM UTC
4 is fixed.
5. Using global  = to select the i index. This is my favorite method.
t.t.
23-Emerald I
Jun 5, 2021 3:54 PM UTC
Let me start by saying that I have NEVER been a fan of combo boxes.  And I'm confused by your sheet.  It seems that there are things missing.  (You need to have T.Cat defined to have vlookup work.)
That said, What you're showing has drawbacks.  For what you've shown, I would build a table.  (Tables replaced  data arrays from Mathcad 15.  If you select data in EXCEL and paste it into Prime, you get a table with blank headers:
One advantage of tables is that they allow units.  (Combo boxes will too, but that can get tricky, look for previous posts!)  In tables, you type variable names and units, and you get arrays.
And a lookup is just as easy:
Jun 9, 2021 5:21 PM UTC
@Fred_Kohlhepp  thanks for that.
At this stage I want to try different methods to give me the best overall options to use Math cad, as have a lot of problems to resolve if I am to be able to make use of this..
Appreciate your thought's on what you consider to be a better product, & have updated the sheet I had to include your suggestion, & tweaked what I can of the others to make it more useful..
ttokoro
ttokoro21-Topaz IAnswer
4 is fixed.
t.t.
