Determinant Code
ptc-6607493
1-Newbie
Determinant Code
Is there a code to calculate the determinant of square matrix by gauss elimination method ?
thank you
5 REPLIES 5
(To:ptc-6607493)
Why would you insist on this specific algorithm?
Simply use the appropriate Mathcad function. Guess internally its not programmed using Gauss.
RichardJ
(To:Werner_E)
Because this is posted in the "Math Homework Help" forum, and Ashley is hoping to find the homework already done? It's not a good way to learn, but it sure saves a lot of time
actually i have proceeded much enough but i cannot end it properly.
RichardJ
(To:ptc-6607493)
Post what you have, preferably with some comments in the worksheet.
Perhaps the following will help: http://en.wikipedia.org/wiki/Gaussian_elimination
