Divide by zero only in a range variable
GerritBarrere
1-Newbie
I'm attaching a Prime 1.0 worksheet that demonstrates a problem I'm having. I'm defining a function with a program which tests for a zero input. This works fine when you invoke the function with a constant or a simple variable of zero, but not when the argument is a range variable including a zero value. Am I doing something wrong, or is there a workaround to this?
Gerrit
11 REPLIES 11
Have a look at the attached if you can open it. There does seem to be a problem when units are involved.
Mike
Just incase you can't open the above file I save included an image for you to follow. Sorry, my Mathcad Prime 1.0 is off at the moment.
Mike
If I vectorize my call to H(f) like you've done it works fine too, even with units. Thank you, Mike! Are you with PTC? Can I consider that this little insect has been reported?
No problem at all. It works for me with units, but when I see a problem I always strip the units away and start from scratch.
Are you with PTC?
No I'm not with PTC
It's actually not a bug. The way to created your range requires the Vectorize function.
Mike
Against my old argument, see below. Mathcad 15 which doesn't need the vectorize function.
Mike
I didn't recall that it did either. In fact, I've done similar things in Prime without having to vectorize. My general philosophy has always been "if it doesn't work, try vectorizing", which I didn't follow this time, alas.
I do think Prime is not quite up to snuff yet. I've seen a number of unexplainable errors, which disappear if you delete part of the equation and then re-enter the identical thing, for example. It's so nice in other ways I'm sticking with it, but it's been really difficult this morning.
Gerrit
I would stick with it Gerrit. Future releases will be a massive improvement.
Mike
Mike's Mathcad 15 example works the same in Mathcad Prime as well.
I was looking at the problem with Gerrit's worksheet, and it appears that the issue is that f is defined as 0 in the program, but f is a vector. So you can't test for 0 this way.
Mona
Hi Mona,
I don't see where f is defined as zero in the program (that is, in the definition of H()). There is a test for the argument being passed being zero. The definition of H as it is should accept a vector f_sub_i and return a vector of the same size, shouldn't it? And if an element of the vector is zero, the test on the first line should catch it. Or am I misunderstanding?
Gerrit
MikeArmstrong
(To:mzeftel)
Mona,
Mathcad 15 works without using the vectorize function and just using the subscript i. Mathcad Prime will not allow this. Are you getting this problem?
Mike
I agree! I'm looking forward to it.
Thanks again for your help,
Gerrit
