Error- "Too few initial conditions" equations
wurjasz
Hello!
I'm trying to solve some equations using command odesolve and all i get is error "too few initial conditions". After using ctrl+f9 it shows, that the problem is caused by constants K. I believe all "start" conditions are included. The document is about chemical reactions and i want to represent on a graph the change of the concentration of the elements in time. I'm using Mathcad 14.
Any ideas of what may be causing this problem?
MJG
18-Opal
18-Opal
(To:wurjasz)
I think this is your problem:
MJG
18-Opal
18-Opal
(To:wurjasz)
wurjasz
(To:MJG)
no comment. thany you.
MJG
18-Opal
18-Opal
(To:MJG)
You get some nice looking graphs after you correct it.
