How to find "t" in this equation
farizriz23
Thank's in advance
6 REPLIES 6
Attach please the Mathcad sheet!
farizriz23
(To:ValeryOchkov)
ok sorry, done..
What is the value of K?
This is needed for the solution.
Cheers
Terry
Not sure if the following is near to what you are looking for:
P6 worksheet attached
Hey,
The hell you mean “what does T mean in algebra” it's a variable the same as X and Y are. If I said “solve the following equation x + 2 = 8.” Your answer would be 6 right. So if I said t + 4 = 6 It would then be 2. T is an unknown variable the same as X and Y are.
