Include worksheet string as variable
SS_9781956
7-Bedrock
Can I pass string variable into the include statement to based on file path as a string variable? Can it be done
ttokoro
20-Turquoise
(To:SS_9781956)
system command to show the current working directory.
Thanks for your response I have an understanding of CWD command.  I’m looking for a way to pass a string variable into the include statement to include a MathCad file based off of the file path stored as a string variable. Is there a way to do this?
Is there a way to make ssmith as a variable  that is in include path?
StuartBruff
(To:SS_9781956)
If you (or your local neighbourhood tame programmer) are up for some programming in a different language in a different environment, then you could see if the Mathcad API would support you in writing a function that inserts a reference.
I've had a quick scan of the API but couldn't see anything, but that's not to say it's not there (I haven't written a Mathcad interface in over a decade).   If you're a support customer, then it might be worth asking the question of PTC.
I suppose there's always something like https://www.autohotkey.com/, which might be combinable with a Mathcad DLL.
Cheers,
Stuart
Hate to be the bearer of bad news.
The answer is no, but it would be a great feature to ask for.
Cheers
Terry
This is needed to grow the API
