I converted a simple document from M15. Came across OK. But the I can't apply/change the style to match my M15 documents.
Help says:
To Apply a Label
1. Select the element that you want to label.
2. On the Math tab, in the Style group, click Labels.
3. Select one of the following labels:
* Variable
* Unit
* Constant
* Function
* System
* Keyword
The selected label is applied to the element.
But it is not. In fact, my styles are greyed out, so I don't think that they are active.
I've gone to Formatting>Label Styles and changed some of the styles. That seems to work.
~R~
Coverted to what?
Mike
M' (Mathcad Prime)...I'm guessing from the paucity of replies that this is a dead thread...So it must work for most of you...I'll keep trying to convert different docs...might just be the one that something went amiss in...
~R~
