Maximum Absolute Value from a set of results
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
Hi, I have this question:
how to get the maximum absolute value from a set of results.
thanks in advance for your help,
- Labels:
Other
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Attaching your worksheet using the advanced editor (see the upper right-hand area of the normal editor) will help people see what you are doing. I strongly suggest you do this.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Have you tried the max() function?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
My situation is:
I have these values o results
A:= 25
B:=-55
C:=54
I need to extratc the maximum absolute value from (A,B and C), in this case is 55
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Doesn't "max(max(A,B,C),-min(A,B,C))=" work??
It should.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
You need to use "Absolute Value" operator:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Another option: stack them into a vector first
If you have a large number of values this version probably minimizes the typing required
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Thank you very much for all your answers,
I'm good now.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
You're welcome.
