Numerical Solutions To Differential Equations
rayakannu2
6-Contributor
Can someone help me with this program. I cannot seem to plot the graphs nor can I get the output matrices.
RA
1 ACCEPTED SOLUTION
LucMeekes
(To:LucMeekes)
Instead of ending the program with [t f u u'']  end it with:
augment(t,f,u,u'')
Then you should be able to plot u versus t for example.
21 REPLIES 21
Show please your ODEs!
here is the zp file
did you get the zip file?
LucMeekes
(To:rayakannu2)
Yep, the zip file was found. I'm limited to Prime Express (no programming a.o.) so I cannot run the program.
At first glance:
In your Solution program you assign n*delta_t to each of the values t[i (That is t with index i). Note that n*delta_t is a constant of 2 seconds. I guess you want to assign i*delta_t to each value of t[i...
Then you go and test the t[i value against, 0, t.1 and t.2 .... Note that there is a difference between t[1 and t.1
t[1 is the second (!) value in the array t, that is because array inexing starts at 0 (controlled by the constant ORIGIN)
t.1 is just a variable t with subscript 1.
Try to correct your sheet with the above notions in mind and come back for further advice if needed.
LucMeekes
(To:rayakannu2)
"help me with this program"
Which program?
Please send in your Mathcad or Prime worksheet.
You may have to zip it first. A serious bug in this forum prevents direct uploading of Mathcad and Prime worksheets for most users. But a .ZIP file can be attached to a posting.
To get the .zip file, use Windows Explorer, select the file, right-mouse click and select "Send to" then "Compressed (.zip) folder". this results in a .zip file containing the worksheet that you can attach.
rayakannu2
6-Contributor
(To:LucMeekes)
hope this works
rayakannu2
6-Contributor
(To:LucMeekes)
Luc, thanks for you help. I got the program to work, but not very sure how to output the all the results. Can you please show me?
LucMeekes
(To:rayakannu2)
You attached the very same sheet file, not the corrected one.
Hence no results for me to work with.
rayakannu2
6-Contributor
(To:LucMeekes)
rayakannu2
6-Contributor
(To:LucMeekes)
Sorry, here it is
LucMeekes
(To:rayakannu2)
You still have a problem in your program.
The calculation for u'' gives units of ft^2/s^4, where it most probably would need to result in ft/s^2.
Correct that and come back when you need more help.
rayakannu2
6-Contributor
(To:LucMeekes)
Luc, I am able to get individual results for t, f, u and u'' not not all the results together. The units are also consistent when individually extracted.
LucMeekes
(To:rayakannu2)
Sorry, my mistake. I multiplied f.i/m with omega^2*u.0, instead of subtracting.
But I do get an error message saying Solution is undefined.
What do you get when you evaluate t[0=
LucMeekes
(To:LucMeekes)
augment(t,f,u,u'')
rayakannu2
6-Contributor
(To:LucMeekes)
Thanks Luc, that worked
-MFra-
(To:rayakannu2)
Hi RA,
you could use the finite difference method below:
rayakannu2
6-Contributor
(To:-MFra-)
Yes, FDM is one of the several ways, and thanks for sharing that program with us. The time intervals need to be no more than 1/10 of the peak forcing function, which means that the number of iterations for a 2 sec response would be in the thousands.
-MFra-
(To:rayakannu2)
Hi ,
For any order matrix, you can do so as indicated below:
rayakannu2
6-Contributor
(To:-MFra-)
Excellent solution procedure, and I will sure try that.
Thanks You very much
rayakannu2
6-Contributor
(To:-MFra-)
I got my program to work, but unable to extract the t, u, and u''. Can you please show me how to display a table of all these values?
