PTC Mathcad Prime 4.0 - file corrupted
mhbaelum
3-Visitor
Hi. I have a problem with some lost work in a Mathcad dok. When i trying to open the file, there is a tekstbox saying - ''Some regions are corrupted and connot be opened''. Can someone help me i this situation? I attached the file.
Best regards.
Try this file.
You are embedding math regions within text regions.  You should be able to do this but it seems to be the problem.
Move all the math regions out of the text regions.  Keep them seperate.  Someone from Mathcad Prime should be given this file.
Cheers Terry
Try this file.
Cheers Terry
Thank you for responding.
The file you uploaded isn't corrupted anymore. But some of the data is still gone. Now i learned a lesson to next time with math regions within text regions even tho I never have had this problem before.
