Plotting issues in MC prime 2.0
ptc-5264820
I'm having trouble plotting a function in MathCad Prime 2.0. Essentially I need to plot various moments of inertia as the angle theta changes. I've tried a couple different things (still a MathCad novice) but nothing seems to work. I've gotten alot of errors saying "there are too many range vairable" and the like. I need the I_base and I_cs functions plotted. Attached is my current worksheet. Feel free to play with it and change some things. Any help would be appreciated.
Look if the attached file helps
Thank you so much Werner. you're a life saver
