Positive and Negative result
KB_10074140
can you help me, sir, for solving this problem, I want to solve (Icr) term?
ttokoro
20-Turquoise
(To:KB_10074140)
Last equation. After you can solve dc, then put the answer to dc.
Unit of right first is m^2, second and third are m^4. So can't solve.
8 REPLIES 8
Attach your worksheet to the message.
KB_10074140
(To:VladimirN)
-thank you sir for your response,
- the file is attached with name (slab bs-5400)
LucMeekes
(To:KB_10074140)
You should ALWAYS attach the Mathcad/Prime worksheet, not just a picture.
Apart from that:
- In the definition for Icr, you should explicitly type a multiplication symbol   *
        between As' and (dc-d)
       as well as between As and (d-dc).
If not As' and As are considered functions.
- If you only need numerical results, you should use the root function, or a solve block, to determine the value of dc.
Note that the symbolic processor of Mathcad/Prime does not 'know about units' by default.
But first: attach your worksheet.
KB_10074140
(To:LucMeekes)
ttokoro
20-Turquoise
(To:KB_10074140)
KB_10074140
(To:ttokoro)
tank you sir for your help.
LucMeekes
(To:KB_10074140)
A single reply (with attachment) will do...
Please see attached Prime 7 file with comments.
KB_10074140
(To:LucMeekes)
thank you very much, sir, for your help.
