In addition to last mail from Thursday there is attached a file with two versions of the program block mentioned.
The program block Largefile.mcdx is the long version, which Prime 3.1 refuces to calculate (to big).
The second program block Largefile_red.mcdx has 18 comment lines less than Largefile.mcdx and workes propperly.
Input data to perform the calculation are included.
Mathcad 14 can handle the larger program without problems.
Günther Polz
If you have a question its better to open a discussion/question rather than a document. We can only comment on your document here nut we cannot attach files.
Maybe you could attach the MC14 /15 version of your file.
Are you contacted with PTC's technical support (and send them your Mathcad Prime file)? Link for "Mathcad Support Center": Mathcad Support Center
