I am trying to work with my final solution but Mathcad is saying the variable is undefined even though it's being defined earlier. I have attached the file. Any help will be really appreciated.
Thank you,
Faisal
I am trying to make a new approach to my work. The problem is one of the parameters has to change after the first calculation step. I tried to make one but it is not working. Please help me through it
I am unable to understand your solution. Can you please explain. My version is 4.0
I think tkoro's post was entered here by mistake. It does not apply.
I usually set the parameters and then calculate or programing something. Thereafter, I make a graph to show the result. After the making of graph, I sometimes check the effect of parameters because to check my calculation is right or wrong. In that case global = is useful to check the effect of parameters at the same bottom position of Mathcad sheet.
Thank you very much FredKohlhepp
