In MC Prime if you do Matrices/Tables/Insert table, you get a table with doodles and brackets etc in the headers to each column. How do you insert a simple table with say 2 rows and 3 columns without these headers, or how do you delete these headers and brackets. I want to insert a text table with part numbers. No math calculations
So why would you want to use a table or matrix if you just want to write Text? Just use a Text Box (Ctrl T).
OR, if you intend to use those text part numbers later again, you may use a matrix of text entries ("") and assign it a variable.
Maybe it helps if you give a small example what you'd like to achieve.
Mathcad probably isn't the ideal tool for that. Everything has a math reason behind it. However, you can use the Excel Component inside Prime to make a simple table.
