Solve-Block Entrapment
Anousheh
6-Contributor
In Prime, I have a plot entrapped inside a solve block. It cannot be dragged out.
Any help and/or suggestion will be greatly appreciated.
Anousheh
LucMeekes
(To:Anousheh)
No worksheet, no problem.
LucMeekes
(To:Anousheh)
Anousheh
6-Contributor
(To:LucMeekes)
Hi Luc,
Thanks for the reply. Before I get your message, I copied the plot and paste it outside of the block and then deleted the entrapped one.
I tried to send you the file containing the original issue but couldn't do it.
I don't know how it entrapped inside the block. I dragged it out and it jumped in again!
Anyway, I found a workaround!
Thanks again,
Anousheh
(To:Anousheh)
Its a silly behavior of Prime, but a region can't be dragged out from within a solve block with the mouse.
But you can just cut and paste it (Ctrl-X, Ctrl-V)
(That means one step less than your solution, which was copy, paste and delete 😉
