Special Insertion of Multiple Vectors into One Vector
hriek
I'm thinking I need for loops to insert vectors P, M and V into Q as follows:
P0 into Q0
P1 into Q3
P2 into Q6
P3 into Q9
M0 into Q1
M1 into Q4
M2 into Q7
M3 into Q10
V0 into Q2
V1 into Q5
V2 into Q8
V3 into Q11
I need help with the programming and sequencing.
MJG
18-Opal
18-Opal
(To:hriek)
In both examples, you can simply change the definition of k from "0...3" to "0...last(P)"
MJG
18-Opal
18-Opal
(To:hriek)
How about this?
No programming needed.
MJG
18-Opal
18-Opal
(To:hriek)
If you want to do it programmatically, you could go this way:
hriek
(To:MJG)
What about for an arbitrary sizes of vectors P, M, V? (these vectors will always be the same size)
MJG
18-Opal
18-Opal
(To:hriek)
