Spline fit
swahlgren
1-Newbie
Spline fit
I'm familiar with using the spline and interp functions in Mathcad to use spline-interpolation of a dataset. Considering a situation where the dataset is noisy, I'd like to be able to fit a spline of n-degrees of freedom rather than creating a spline that goes through all datapoints. I can't find any help in the Mathcad documentation so input from you guys would be much appreciated.
I can see it exists for Matlab: File Exchange - MATLAB Central
1 ACCEPTED SOLUTION
RichardJ
(To:swahlgren)
In Mathcad 15, go to "Help", "E-books", "Data Analysis Extension Pack", Under "Non-parametric fitting / Interpolation", choose "B-Splines and Least-Squares Splines". If you are using Prime I'll have to figure out where the information is.
6 REPLIES 6
RichardJ
(To:swahlgren)
I'm afraid no E-books are available for me, can it be attached here?
RichardJ
(To:swahlgren)
Which version of Mathcad are you using?
Here's the relevant section, but if you don't have the Data Analysis Extension pack installed then spline2 will not work.
Found it; just had to browse to the handbook file. Thanks man!
Spline fit a strange name. Must be spline interpolation!
Not if it's a least squares spline.
