basic EE tasks
jstavitsky
1-Newbie
basic EE tasks
Howdy folks
EE freshman here, just a few basic questions.
Phase shift as used in the cartesian to polar conversion uses the complement of the angle in the second and third quadrants (ie when the real part is negative). How best to do this?
Where is Hz and Hza originally defined? I can't see it in worksheet options>unit system
How best to implement functions like
In fact, is the angle symbol even in mathcad? I can't find it.
Thanks much in advance
Joe
2. One example in Mathcad 15:
6 REPLIES 6
1. See new complex number format in Mathcad Prime:
You mean it took them 16 numbered versions to do this? unreal.
So first you must define this function and then this calculation will occur?
Thanks again
Joe
In older versions, the attached demonstrates a special function that you must add to your worksheet (right hand side of the worksheet). Tou can copy & paste the example and use what you require.
I hope this helps.
Norm
Still can't get #3 to work tho, sorry.
