Hi everybody!
Is there anyone who can tell me what to do (or how to avoid the error) when, (MATHCAD 14 S. E.) with automatic calculation disabled, while saving, appears: "A generic error occurred in GDI +" and I can no longer save the file?
Hi!
maybe, I've found the cause generating the error ... The autosave, and continuous backup are incompatible or something like that, in fact disabling the backup unit, it seems that the error does not occur.
Can you provide this worksheet?
Hello Vladimir! I would prefer do not to provide the file. In it there are many references, without which there would be numerous error messages. However, I can add that when I open it I have to redo the corrections and the saving is successful.
I'm curious what corrections you have made to a worksheet and then successfully saved?
Hi!
Thank you.
