symbolic calculation in quantum mechanics
ptc-4495199
Hello all,
I want to reproduce with Mathcad some symbolic quantum mechanics calculations done with Mathematica.
It is just standard homework question.
Occasionally, the correct formal equation just stall.
It is a lost cause or does it some special syntax I am not aware of ?
I am using Mathcad 15.
Thanks for the help,
Pierre
I chanced upon this today, and wondered if you were pursuing the inner product, not the sum of the elements squared...note the assignment of a symbolic result to a variable...The latest Mathematica has more support for QM symbolics, but overall it seems that it will not quite do as much for me as Mathcad, though my work is more "concrete", even when addressing theoretical physics questions.
8 REPLIES 8
These integrals are too difficult for the Mupad symbolic engine in M15 to deal with. Since Hermite polynomials have a simple recurrence relationship it's possible the approach illustrated below might be of some use to you.
Alan
RichardJ
(To:AlanStevens)
Great answer
I have got a strange result.
The sum of squared matrix elements gives "55" where it should show just "5".
When I check the elements individually, it shows that the sum should be 5 !
What happened ?
Pierre
RichardJ
(To:ptc-4495199)
If you don't vectorize, the product of two vectors is a scalar: the dot product.
Also, you can't sum over the range of n=0 to 10, because n does not appear as an index in the expression. Just use a vector sum.
It looks better.
Thanks again,
Pierre
Hi Rich,
Thanks for the feedback.
Sorry for the late reply.
I did not have a chance to do symbolic QM calculation since the last semester.
But it looks like you provided the right path.
Note that with my notation, hb stands for h barr (h.b is a misunderstanding of the notation).
Thanks again,
Pierre
Hi Allan,
It looks great.
Pierre
