Hey I'm a student and at school we use mathcad 14. I decided to download the free mathcad express prime to try and be able to work on my homework and class problems outside of school. I've tried typing in exactly what we did in class (which worked perfectly) into the free mathcad express and nothing seems to be working and can't figure out how to type some of the functions into the program. Here is the part that was giving me the most trouble. the left is what we did in class (on a word document) and right is my attempt at inputting it into mathcad express.
.png)
It looks like it is a difference between the array subscript & the literal subscript.
if you look very closely, the array subscript operator is wholly below the array name whereas the literal subscript is only 1/2 line down.
The array subscript is written either through the operator button on the ribbon or with '['.
The literal subscript with the subscript button or <ctrl> -
file attached
There is also the possibility that there is confusion with the label set for the various names used ( prime is bad for this) .
there are formatting differences - so in the pictures shown, it doesn't appear to be this.
It is easier to solve the 'correct' problem if the file is attached.
Regards
Andy
Please attach your Mathcad Prime worksheet to the message by using "Use advanced editor".
Its hard to debug a picture. Especially as you don't show the errormessage you get either.
Could it be that you mixed up literal indices and matrix indices?
From what I see it look like you should use matrix indices throughout. The keyboard shortcut is [ in both versions of mathcad.
WE
file attached
Regards
Andy
Thank You! That worked awesome didn't realize there was two separate ways . But all works perfectly now!
