'Check in As' multiple topics
ptc-5440868
Hi All, I am pretty new to Arbortext and I am facing a problem. I have a couple of projects under a root folder and each project has multiple topics. I created a new project and I wanted to 'Check in As' the topics from the projects to the new project. However, it has really become a tedious task as I have to manually 'check in as' each topic one by one. Is there any way I can manually 'check in as' multiple topics at the same time?
What I am currently doing is that I first view the topic and then use the option SDL Live Content > Check in As.
Any help would be hugely appreciated.
Thanks in advance.
Avishekh
1 REPLY 1
Hi Avishekh
That sounds like an SDL Live Content issue. Check with your rep or SDL technical support.
Liz
Learn more about PTC/USER
FlexPLM Blog Post
Windchill Blog Post
PTC/USER Global Summit
The Global Summit is the largest annual gathering of PTC/USER members—featuring a jam packed agenda of content and opportunities to mingle with and learn from your peers. Join us in Las Vegas!
