Expression to determine which participant has voted for which option.
ptc-4767031
Hi all,
I have an activity in a custom workflow which has two routing options yes and no.There are two roles associated with that activity as participants.They give their votes as yes or no.All these votes go to the creator in the next activity and the creator resends the task to only that person who has given his vote as yes. and any other participant who has given vote as yes should not get the task back.
So how should i go about it..iam trying to write an expression to get which participant has given which vote but iam not getting any method for that in workflow.
Please help me as soon as possible.
1 REPLY 1
Hello
for example in the Terminate transition of the activity you can use thise code
// get the user
wt.org.WTPrincipalReference user;
WfAssignedActivity activity= (wt.workflow.work.WfAssignedActivity)self.getObject();
java.util.Enumeration allassig2 = activity.getAssignments();
while (allassig2.hasMoreElements())
Object a2= allassig2.nextElement();
java.util.Enumeration balots = ((wt.workflow.work.WfAssignment)a2).getBallots();
while (balots .hasMoreElements())
Object bal= balots .nextElement();
user = ((WfBallot)bal).getVoter();
from the WFBallot , I think you're also able to get the value of the vote ...
regards
Learn more about PTC/USER
FlexPLM Blog Post
Windchill Blog Post
PTC/USER Global Summit
The Global Summit is the largest annual gathering of PTC/USER members—featuring a jam packed agenda of content and opportunities to mingle with and learn from your peers. Join us in Las Vegas!
