Reply to ask for help or share what you have learned.
On page 55, step nº7 - The "select Revision glyph" icon does not appear in the revise menu. It doesn't work with any browser.
I tested the exercise and I could see the icon.
Maybe you are looking for the icon at the ribbon, but it will appear at the New Revision column,
Please, see the attached image.
You can see the video that shows the exercise steps:
https://learningconnector.ptc.com/tutorial/1751268341203/set-preferences
Did you skip any steps? Please, let me know if the issue persists.
Ok. Maybe my preferences are not correctly. Thank you for your fast reply.
